Verizon iPhone 4 Chargers & Cables
Top 10 Chargers & Cables for Verizon iPhone 4
| 1 | ![]() | Apple USB Power Adapter w/ Sync Cable Featuring a compact design, this convenient USB-based power adapter offers fast, efficient charging at home, in the office, or on the go. It works with Verizon iPhone 4 and all iPod models with a dock connector.Simply plug the adapter into a wall outlet a...(more) |
$14.95 | ||
| 2 | ![]() | Griffin PowerJolt 2.1 Amp Just plug in and charge from your car’s 12V power outlet. The low-profile design of the Griffin PowerJolt uses an illuminated light ring to indicate charge status. PowerJolt's detachable dock cable can be used separately to charge and sync your ...(more) |
$22.95 | ||
| 3 | ![]() | Smartphone Experts 500mA Car Charger Recharge [[your_works_with]] on the road with this compact car charger. Perfect for those days you forget to recharge at home, at the office, or when you get stuck in traffic. Fits easily in a glove compartment or door pocket.
18 inches coiled, 5 foot ...(more) |
$9.95 | ||
| 4 | ![]() | Ventev 1A MFI USB EcoCHARGE Ventev EcoCharge MFI USB travel charger is made with care, precision, and confidence to be one of the most eco-friendly cellular phone chargers out there. It has the lowest "stand by" power draw on the market. It also has dual charging capabilities with a...(more) |
$12.95 | ||
5![]() | 6![]() |
| Apple Dock Connector to USB Cable for Verizon iPhone 4 This USB 2.0 cable connects your iPhone or iPod — directly or through a Dock — to your computer's USB port for efficient syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet.Features:OEM Appl...(more) | Bluelounge MiniDock for Verizon iPhone 4 The Bluelounge MiniDock allows you to charge your favorite iPhone or iPod with your existing Apple USB Power Adapter. Your device sits upright in the MiniDock while it charges directly into the wall socket, allowing you to free up counter or tabletop s...(more) |
$9.95 | $19.95 |
| More USB Cables | More USB Chargers |
7![]() | 8![]() |
| Griffin 3 Meter USB to Dock Cable for Verizon iPhone 4 The Griffin 3 Meter USB to Dock Cable is almost 10 feet long and built with heavy-duty 20-gauge conductors to handle the 2.1 amp power needs of [[your_works_with]]. Connect this cable to your computer's USB port to sync [[your_works_with]]; or to an...(more) | Seidio Desktop Charging Cradle for Verizon iPhone 4
This convenient desktop cradle keeps [[your_works_with]] charged and ready to go. Sync and charge [[your_works_with]] without the hassle of removing your SURFACE, ACTIVE, and ACTIVE X case. Dock [[your_works_with]] with your computer using the included ...(more) |
$29.95 | $26.95 |
| More USB Cables | More Charging Docks |
9![]() | 10![]() |
| Qmadix Docking Station Adapter for Verizon iPhone 4 The Qmadix Docking Station Adapter allows you to dock your IOS device while using your favorite protective case.
Thicker protective cases require removal prior to using them with most docking devices. This slim IOS 30 pin adapter extends your connector h...(more) | Naztech N300 3 in 1 USB Charger for Verizon iPhone 4 Designed for life on-the-go, the ultra-portable n300 gives you the freedom to go farther and stay connected. The high performance Naztech n300 rapid charger combines an AC adapter for wall outlets, a DC adapter for cigarette lighters and a USB cable for c...(more) |
$16.95 | $22.95 |
| More Charger Adapters | More USB Chargers |
