Shop accessories for other smartphones with a single cart:   Android Devices   BlackBerry   iPhone & iPad   Windows Phone   WebOS Devices
iPhone 5 Chargers & Cables
Top 10 Chargers & Cables for iPhone 5
1Apple Lightning to USB CableApple Lightning to USB Cable
This Apple USB 2.0 cable connects your iPhone, iPad, or iPod with Lightning connector to your computer's USB port for syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet. The cable measures approximately 3.5 ...(more)
  (4 ratings)
$24.95
2Aduro Lightning to USB Sync Cable 10FTAduro Lightning to USB Sync Cable 10FT
The Aduro Lightning to USB Sync Cable works with [[your_works_with]] providing sync via your computers USB port. This 10-foot cable can be used at the office or home. Features: USB to Lightning connector Compatible with iPhone 5 Length: 10 ft Use ...(more)
  (14 ratings)
$22.95
3SCOSCHE strikeDRIVE 5W 1A Car ChargerSCOSCHE strikeDRIVE 5W 1A Car Charger
Quick charge your new Apple Lightning device in the car with the strikeDRIVE 5W 1A Car Charger by SCOSCHE. 5 Watts of power will charge most devices as quickly and efficiently as possible. Charge the iPhone 5, iPod touch (5th gen) and iPod nano (7th gen)...(more)
  (2 ratings)
$23.95
4AZURA 6ft USB to Lighting Charge & Sync CableAZURA 6ft USB to Lighting Charge & Sync Cable
Charge and sync [[your_works_with]] at the speed of light with the AZURA USB Sync & Charge Cable, a multi-purpose cable that can do your multitasking for you! The AZURA USB Lightning Compatible Cable is 6 ft in length (twice the length of standard OE...(more)
  (2 ratings)
$22.95
5Belkin 2.1A USB Car Charger with Lightning Connector6Bluelounge CableDrop Cable Management System for iPhone 5
Charge [[your_works_with]] on the road with this Belkin USB Car Charger with Lightning connector and get unlimited play and standby time with the low-profile design that sits flush in your dash. Charge [[your_works_with]] at the fastest possible speed wi...(more)
Anywhere you wish to have cables temporarily held yet easily removed or extended, CableDrop gently grasps your power and peripheral cords so they do not fall off your desk every time you unplug [[your_works_with]]. The ever popular CableDrop manages your ...(more)
Score 4/5 (4 ratings)
$31.95
Score 4.8/5 (5 ratings)
$9.95
More Car ChargersMore USB Cables
7Belkin 2.1A Swivel Wall Charger with Lightning Connector8Mobi Products Lightning to USB Cable for iPhone 5
The Swivel Charger rotates 90 degrees to accommodate crowded A/C outlets and make room for other plugs and folding prongs make it simple to stick in a bag for charging on the go. The USB Port is universal, so you can still charge your legacy Apple device...(more)
The Mobi Lightning to USB Cable connects [[your_works_with]] to a USB port or charging adapter to power up your device when you need it most. This cable stretches approximately 40 inches in length and offers both syncing and charging capabilities. Featu...(more)
Score 5/5 (1 ratings)
$34.95
Score 3/5 (5 ratings)
$14.95
More Wall ChargersMore USB Cables
9Solio Classic2 Battery Pack + Solar Charger for iPhone 510Griffin 3 ft USB to Lightning Cable
Boasting twice the capacity of the original CLASSIC charger, a day of sun gives you three complete charges on your portable electronic devices. The CLASSIC2 features a full-sized USB port allowing thousands of devices to easily connect, just by using thei...(more)
Free Shipping
  The Griffin 3 feet USB to Apple Lightning cable is perfect for charging and/or syncing [[your_works_with]]. The 3 feet of cable gives you the freedom to use your device while it charges and the durable cable jacket protects wire cores and resists ...(more)
Score 5/5 (2 ratings)
$89.95
Score 3.5/5 (2 ratings)
$17.95
More Solar & Emergency ChargersMore USB Cables
My iPhone 5
Shop by Category
Customer Care
Powered by...
Our Customers Say...
