Shop accessories for other smartphones, one-cart checkout:   Palm Pre   BlackBerry   Android Devices   iPhone   Windows Phone
iPhone 4S Car Kit Parts
Popular Makes of Car Kit Parts
Browse Car Kit Parts for iPhone 4S
Show
Sort
iGrip miniGripper Universal Holder for iPhone 4SiGrip miniGripper Universal Holder for iPhone 4S
Need a replacement Phone Holder for your iGrip Mount? This sturdy phone holster is exactly what you need to ensure your device stays safe and secure while mounted.
$12.95Score 3.6/5Score 3.6/5Score 3.6/5Score 3.6/5Score 3.6/5 (34)In StockAdd iGrip miniGripper Universal Holder for iPhone 4S to Cart
iGrip Cigarette Lighter Mount for iPhone 4SiGrip Cigarette Lighter Mount for iPhone 4S
Need a replacement Cigarette Lighter Mount? This sturdy mounting solution will ensure that your device stays safe and secure in the position you desire.
$9.95Score 4.1/5Score 4.1/5Score 4.1/5Score 4.1/5Score 4.1/5 (10)In StockAdd iGrip Cigarette Lighter Mount for iPhone 4S to Cart
iGrip Sturdy Swivel Mount for iPhone 4SiGrip Sturdy Swivel Mount for iPhone 4S
The iGrip Sturdy Swivel Mount can easily be adjusted up and down and sideways for optimal viewing angles.
$16.95Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (7)In StockAdd iGrip Sturdy Swivel Mount for iPhone 4S to Cart
iGrip Flexible Mount for iPhone 4SiGrip Flexible Mount for iPhone 4S
The iGrip Flexible Mount is a suction mount with a strong, freely adjustable arm that adjusts the device holder to any viewing angle, and provides a safe and secure mounting for your device.
$9.95Score 2.9/5Score 2.9/5Score 2.9/5Score 2.9/5Score 2.9/5 (14)In StockAdd iGrip Flexible Mount for iPhone 4S to Cart
iGrip Vent Mount for iPhone 4SiGrip Vent Mount for iPhone 4S
The iGrip Vent Mount is a sturdy mount that features adjustable vent clips on the back that allow mounting on vertical or horizontal vent fins.
$9.95Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5 (16)In StockAdd iGrip Vent Mount for iPhone 4S to Cart
Krusell Windshield Mount for iPhone 4SKrusell Windshield Mount for iPhone 4S
Perfect compliment for attaching your Krusell case to a windshield. Attaches to your windshield or other similar surface via a suction cup.
$14.95Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5 (8)In StockAdd Krusell Windshield Mount for iPhone 4S to Cart
THB BURY Mount Adjustable Knuckle for iPhone 4STHB BURY Mount Adjustable Knuckle for iPhone 4S
Mount Adjustable Knuckle with 4 fixing points is used to attach phone cradles to an amps plate. To be used with Bury installed car kits only.
$27.95'Not yet rated.'In StockAdd THB BURY Mount Adjustable Knuckle for iPhone 4S to Cart
iGrip Custom Fit Holder (Without Mount) for iPhone 4SiGrip Custom Fit Holder (Without Mount) for iPhone 4S
iGrip Custom Fit Holder (Without Mount) is exclusively designed to fit the iPhone 4S.
$12.95Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5 (3)In StockAdd iGrip Custom Fit Holder (Without Mount) for iPhone 4S to Cart
iGrip Dual-Support Suction Mount for iPhone 4SiGrip Dual-Support Suction Mount for iPhone 4S
The iGrip Dual-Support Suction Mount is a versatile, elegant suction mount that is compact and foldable.
$16.95Score 3.9/5Score 3.9/5Score 3.9/5Score 3.9/5Score 3.9/5 (9)In StockAdd iGrip Dual-Support Suction Mount for iPhone 4S to Cart
PanaVise Ultra Low-Profile Dash Mat for iPhone 4SPanaVise Ultra Low-Profile Dash Mat for iPhone 4S
The PanaVise Ultra Low-Profile Dash Mat has a 3.5-inch diameter disc designed for use with a suction-cup mount and uses a non-skid, non-adhesive surface to seamlessly contour to your dashboard while you drive.
$13.95'Not yet rated.'In StockAdd PanaVise Ultra Low-Profile Dash Mat for iPhone 4S to Cart
Shop by Category
Customer Care
Powered by...
Our Customers Say...
