Shop accessories for other smartphones with a single cart:   Android Devices   BlackBerry   iPhone & iPad   Windows Phone   WebOS Devices
iPhone 3GS Car Kit Parts
Browse Car Kit Parts for iPhone 3GS
Sort By:
Narrow By:
iGrip miniGripper Universal Holder for iPhone 3GSiGrip miniGripper Universal Holder for iPhone 3GS
Need a replacement Phone Holder for your iGrip Mount? This sturdy phone holster is exactly what you need to ensure your iPhone 3GS stays safe and secure while mounted.
$12.95  $15.00Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (55)Out of StockAdd iGrip miniGripper Universal Holder for iPhone 3GS to Cart
iGrip Cigarette Lighter Mount for iPhone 3GSiGrip Cigarette Lighter Mount for iPhone 3GS
Need a replacement Cigarette Lighter Mount? This sturdy mounting solution will ensure that your iPhone 3GS stays safe and secure in the position you desire.
$9.95  $15.00Score 3.2/5Score 3.2/5Score 3.2/5Score 3.2/5Score 3.2/5 (22)Out of StockAdd iGrip Cigarette Lighter Mount for iPhone 3GS to Cart
iGrip Sturdy Swivel Mount for iPhone 3GSiGrip Sturdy Swivel Mount for iPhone 3GS
The iGrip Sturdy Swivel Mount can easily be adjusted up and down and sideways for optimal viewing angles.
$16.95  $20.00Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5 (8)In StockAdd iGrip Sturdy Swivel Mount for iPhone 3GS to Cart
iGrip Flexible Mount for iPhone 3GSiGrip Flexible Mount for iPhone 3GS
The iGrip Flexible Mount is a suction mount with a strong, freely adjustable arm that adjusts the device holder to any viewing angle, and provides a safe and secure mounting for your iPhone 3GS.
$9.95  $15.00Score 2.7/5Score 2.7/5Score 2.7/5Score 2.7/5Score 2.7/5 (19)In StockAdd iGrip Flexible Mount for iPhone 3GS to Cart
iGrip Vent Mount for iPhone 3GSiGrip Vent Mount for iPhone 3GS
The iGrip Vent Mount is a sturdy mount that features adjustable vent clips on the back that allow mounting on vertical or horizontal vent fins.
$9.95  $15.00Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5 (17)In StockAdd iGrip Vent Mount for iPhone 3GS to Cart
Krusell Windshield Mount for iPhone 3GS50%Krusell Windshield Mount for iPhone 3GS
Perfect compliment for attaching your Krusell case to a windshield. Attaches to your windshield or other similar surface via a suction cup.
$9.95  $19.95Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5 (8)In StockAdd Krusell Windshield Mount for iPhone 3GS to Cart
iGrip Custom Fit Holder (Without Mount) for iPhone 3GSiGrip Custom Fit Holder (Without Mount) for iPhone 3GS
Custom designed, this holder works with your iPhone 3GS. Slide & go! Your Smartphone conveniently slides into place and is held securely at all times.
$9.95  $15.00Score 4.7/5Score 4.7/5Score 4.7/5Score 4.7/5Score 4.7/5 (3)In StockAdd iGrip Custom Fit Holder (Without Mount) for iPhone 3GS to Cart
THB BURY Mount Adjustable Knuckle for iPhone 3GSTHB BURY Mount Adjustable Knuckle for iPhone 3GS
Mount Adjustable Knuckle with 4 fixing points is used to attach phone cradles to an amps plate. To be used with Bury installed car kits only.
$27.95  $38.99'Not yet rated.'In StockAdd THB BURY Mount Adjustable Knuckle for iPhone 3GS to Cart
iGrip Dual-Support Suction Mount for iPhone 3GSiGrip Dual-Support Suction Mount for iPhone 3GS
The iGrip Dual-Support Suction Mount is a versatile, elegant suction mount that is compact and foldable.
$16.95  $20.00Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (11)In StockAdd iGrip Dual-Support Suction Mount for iPhone 3GS to Cart
PanaVise Ultra Low-Profile Dash Mat for iPhone 3GSPanaVise Ultra Low-Profile Dash Mat for iPhone 3GS
The PanaVise Ultra Low-Profile Dash Mat has a 3.5-inch diameter disc designed for use with a suction-cup mount and uses a non-skid, non-adhesive surface to seamlessly contour to your dashboard while you drive.
$8.95  $9.99Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5 (3)In StockAdd PanaVise Ultra Low-Profile Dash Mat for iPhone 3GS to Cart
My iPhone 3GS
Shop by Category
Customer Care
Powered by...
Our Customers Say...
