iPad Air USB Cables
Browse USB Cables for iPad Air
Sort by:
Narrow By:
Apple 3ft Lightning to USB Cable for iPad AirApple 3ft Lightning to USB Cable for iPad Air
This Apple USB 2.0 cable connects your iPhone, iPad, or iPod with Lightning connector to your computer's USB port for syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet.
$14.95  $19.99Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (6)In StockAdd Apple 3ft Lightning to USB Cable for iPad Air to Cart
Griffin Technology 3 ft USB to Lightning Cable for iPad AirGriffin Technology 3 ft USB to Lightning Cable for iPad Air
The Griffin 3 feet USB to Apple Lightning cable is perfect for charging and/or syncing your iPad Air.
$16.95  $18.99Score 3.5/5Score 3.5/5Score 3.5/5Score 3.5/5Score 3.5/5 (2)In StockAdd Griffin Technology 3 ft USB to Lightning Cable for iPad Air to Cart
TYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad AirTYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad Air
The TYLT SYNCABLE Charge & Sync Lightning Connector charges your mobile device via any USB power source, such as a USB car charger, wall charger, PC or laptop with no messy cables to get kinked.
$22.95  $29.99Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (3)In StockView TYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad Air Options
AZURA 6ft USB to Lightning Charge & Sync Cable for iPad AirAZURA 6ft USB to Lightning Charge & Sync Cable for iPad Air
Charge and sync your iPad Air at the speed of light with the AZURA USB Sync & Charge Cable, a multipurpose cable that can do your multitasking for you!
$21.95  $29.99Score 4.9/5Score 4.9/5Score 4.9/5Score 4.9/5Score 4.9/5 (7)In StockAdd AZURA 6ft USB to Lightning Charge & Sync Cable for iPad Air to Cart
Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air48%Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air
Ventev's flat, tangle-resistant Charging Data Cable charges your iPad Air and transfers your favorite photos, music, videos and more with ease.
$12.95  $25.00'Not yet rated.'In StockView Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air Options
SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad AirSCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad Air
The smartSTRIKE is a 2-in-1 charge and sync cable that will charge both devices at any time; without the fuss!
$21.95  $24.99'Not yet rated.'In StockAdd SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad Air to Cart
Incipio Lightning Charge/Sync Cable 3.3ft for iPad AirIncipio Lightning Charge/Sync Cable 3.3ft for iPad Air
Why not compliment your lightning-compatible Apple device with one of these high quality, vibrant colored charge and sync cables from Incipio!
$9.95  $19.99'Not yet rated.'In StockAdd Incipio Lightning Charge/Sync Cable 3.3ft for iPad Air to Cart
Belkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad AirBelkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad Air
This two-meter (6.6-foot) cable features a reversible Lightning connector on one end and a USB plug on the other for convenient charging or syncing with your iTunes library.
$24.95  $29.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Belkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad Air to Cart
Amzer MFi Certified Sync & Charge Lightning to USB Cable (6 Feet/1.8 Meters) for iPad AirAmzer MFi Certified Sync & Charge Lightning to USB Cable (6 Feet/1.8 Meters) for iPad Air
Great for charging your lightning device at the office, at home or while you travel, Amzer's MFi Lightning Cable provides 6ft. of length for optimum management and convenience!
$14.95  $19.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Amzer MFi Certified Sync & Charge Lightning to USB Cable (6 Feet/1.8 Meters) for iPad Air to Cart
KERO 3" Apple Lighting Nomad Cable for iPad AirKERO 3" Apple Lighting Nomad Cable for iPad Air
Carry the KERO Lightning Nomad Cable with you wherever you go and ensure that your lightning-compatible device stays charged!
$13.87  $29.99'Not yet rated.'In StockView KERO 3" Apple Lighting Nomad Cable for iPad Air Options
Ventev 6ft Lightning to USB Charging Data Cable for iPad AirVentev 6ft Lightning to USB Charging Data Cable for iPad Air
Now you can charge your Lightning device without worrying about knots and tangles! Ventev's Charging Data Cable provides 6 feet of convenient charging and syncing whenever you need it.
$18.95  $29.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (2)In StockView Ventev 6ft Lightning to USB Charging Data Cable for iPad Air Options
mophie 4-inch Memory-Flex USB Lightning Cable for iPad Airmophie 4-inch Memory-Flex USB Lightning Cable for iPad Air
This super-flexible, high-current 4-inch cable charges and syncs any of your Apple devices with a Lightning connector and barely takes any space in your bag or at your desk!
$21.95  $24.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockView mophie 4-inch Memory-Flex USB Lightning Cable for iPad Air Options
Belkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad AirBelkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad Air
The 90-degree angle protects the plug and alleviates strain on the cable. The Lightning connector makes it simple to sync and charge a variety of portable Apple devices.
$18.95  $24.99'Not yet rated.'In StockView Belkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad Air Options
KODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad AirKODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad Air
Original Kodiak Lightning MFI Charging-Data Cable Aluminum Housing Silver 6.6ft / 2m
$18.95  $24.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (3)In StockView KODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad Air Options
Ventev 6 in. Lightning Cable for iPad Air48%Ventev 6 in. Lightning Cable for iPad Air
Flat & tangle-resistant, Ventev 6 in. chargesync cables are engineered to support higher output chargers, delivering up to 2.4A for Apple Lightning devices. Great length for portable battery chargers.
$11.95  $22.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Ventev 6 in. Lightning Cable for iPad Air to Cart
Seidio Lightning USB Cable (0.2m) for iPad AirSeidio Lightning USB Cable (0.2m) for iPad Air
The Lightning Cable (0.2m) with high connectivity is a great way to keep your your iPad Air charged and updated for use.
$9.95  $14.95'Not yet rated.'In StockAdd Seidio Lightning USB Cable (0.2m) for iPad Air to Cart
Seidio Lightning USB Cable (1.0m) for iPad Air40%Seidio Lightning USB Cable (1.0m) for iPad Air
The Lightning Cable (1.0m) with high connectivity is a great way to keep your your iPad Air charged and updated for use.
$9.00  $14.95Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (3)In StockAdd Seidio Lightning USB Cable (1.0m) for iPad Air to Cart
Seidio Lightning USB Cable (2.0m) for iPad AirSeidio Lightning USB Cable (2.0m) for iPad Air
The Lightning Cable (2.0m) with high connectivity is a great way to keep your iPad Air or iPad charged and updated for use.
$16.95  $19.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Seidio Lightning USB Cable (2.0m) for iPad Air to Cart
[Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air[Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air
Meet TITAN LOOP - The Toughest Key Chain Cable on Earth. TITAN LOOP extends to nearly 25cm / 9in long, but loops in half to attach to your key chain, belt loop, backpack, or MacBook bag.
$24.95  $24.95'Not yet rated.'In StockAdd [Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air to Cart
[Fuse] Chicken TITAN Lightning USB Cable for iPad Air[Fuse] Chicken TITAN Lightning USB Cable for iPad Air
The frayed cables, cords tied in knots, and the family pet chewing on our charger. TITAN solves all of that and more with its industrial-grade cable.
$25.00  $34.95'Not yet rated.'In StockAdd [Fuse] Chicken TITAN Lightning USB Cable for iPad Air to Cart
Mobi Products 3-in-1 USB Charging Cable for iPad AirMobi Products 3-in-1 USB Charging Cable for iPad Air
The Mobi Products 3-in-1 USB Charging Cable includes a Lightning, Micro-USB, and USB Type-C connections. Now you have the ability to charge different devices simultaneously.
$12.00  $15.00'Not yet rated.'In StockAdd Mobi Products 3-in-1 USB Charging Cable for iPad Air to Cart
My iPad Air
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
