iPad Air Car Chargers
Browse Car Chargers for iPad Air
Sort by:
Narrow By:
TYLT Band Car Charger 2.1A Lightning Connector for iPad AirTYLT Band Car Charger 2.1A Lightning Connector for iPad Air
The TYLT Band Car Charger 2.1A Lightning Connector features a seamless design made from silicone, so it's soft, pliable and tangle free.
$23.00  $49.99'Not yet rated.'In StockAdd TYLT Band Car Charger 2.1A Lightning Connector for iPad Air to Cart
Ventev 2A Lightning Car Charger with USB Port for iPad Air46%Ventev 2A Lightning Car Charger with USB Port for iPad Air
With Ventev's 2A Apple Lightning Car Charger with USB port you can keep your device juiced up while your passenger does the same, right off your cable!
$18.95  $34.99Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (3)Out of StockAdd Ventev 2A Lightning Car Charger with USB Port for iPad Air to Cart
Just Mobile 2.1A Highway Duo Car Charger for iPad AirJust Mobile 2.1A Highway Duo Car Charger for iPad Air
Just Mobile Highway Duo™ is the dual-use in-car charger for iPhone and iPad.
$38.95  $39.95'Not yet rated.'In StockAdd Just Mobile 2.1A Highway Duo Car Charger for iPad Air to Cart
Amzer 10A/50W 4-Port USB Car Charger with Intelligent Rapid Charge Technology for iPad AirAmzer 10A/50W 4-Port USB Car Charger with Intelligent Rapid Charge Technology for iPad Air
This device quickly, easily and efficiently charges both high and low-current USB outputs.
$14.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (6)Out of StockAdd Amzer 10A/50W 4-Port USB Car Charger with Intelligent Rapid Charge Technology for iPad Air to Cart
iOttie RapidVOLT Max 5A Dual Port USB Car Charger for iPad AiriOttie RapidVOLT Max 5A Dual Port USB Car Charger for iPad Air
The iOttie RapidVOLT MAX allows you to quickly and efficiently charge all of your devices on the go. Included is a green LED light that will inform you that the RapidVOLT Max is on and working.
$12.95  $19.95'Not yet rated.'In StockView iOttie RapidVOLT Max 5A Dual Port USB Car Charger for iPad Air Options
Amzer 2800mAh 2-Port USB Power Bank Car Charger for iPad AirAmzer 2800mAh 2-Port USB Power Bank Car Charger for iPad Air
Keep all of your handheld gadgets fully charged with this handy 2 Port USB Power Bank and Car Charger! Simply plug into your vehicle power socket and you can charge up to two devices simultaneously!
$24.95  $29.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Amzer 2800mAh 2-Port USB Power Bank Car Charger for iPad Air to Cart
RUIZ 2.1A (10W) USB Car Charger for iPad Air44%RUIZ 2.1A (10W) USB Car Charger for iPad Air
Charge your Apple or Android device with existing USB cables at fast speeds as you drive to your destination.
$8.95  $15.99Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (1)In StockAdd RUIZ 2.1A (10W) USB Car Charger for iPad Air to Cart
KODIAK 6.6A Car Charger 3-in-1 Lightning  MFI with 2 USB Ports for iPad AirKODIAK 6.6A Car Charger 3-in-1 Lightning MFI with 2 USB Ports for iPad Air
Smart charging for power-savvy users is here. Experience a worry-free journey when you are on the go.
$22.95  $29.99Score 4.5/5Score 4.5/5Score 4.5/5Score 4.5/5Score 4.5/5 (2)In StockView KODIAK 6.6A Car Charger 3-in-1 Lightning  MFI with 2 USB Ports for iPad Air Options
Cellet 2.4A 4-Port USB Car Charger with USB Hub for iPad AirCellet 2.4A 4-Port USB Car Charger with USB Hub for iPad Air
Charge 4 devices at the same time and keep everybody happy with Cellet’s 4 USB port car charger.
$22.95  $29.99'Not yet rated.'In StockAdd Cellet 2.4A 4-Port USB Car Charger with USB Hub for iPad Air to Cart
Samsung 2A AFC Dual-Port USB Vehicle Charger (Data Cable not Included) for iPad AirSamsung 2A AFC Dual-Port USB Vehicle Charger (Data Cable not Included) for iPad Air
The Samsung Fast Charging Dual-Port Vehicle Charger plugs into any standard vehicle power outlet via the included CLA adapter, and its compact design means it is small enough to not get in the way while driving
$19.95  $29.99'Not yet rated.'In StockAdd Samsung 2A AFC Dual-Port USB Vehicle Charger (Data Cable not Included) for iPad Air to Cart
My iPad Air
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
