iPad Air 2 USB Cables
Browse USB Cables for iPad Air 2
Sort by:
Narrow By:
Apple 3ft Lightning to USB Cable for iPad Air 2Apple 3ft Lightning to USB Cable for iPad Air 2
This Apple USB 2.0 cable connects your iPhone, iPad, or iPod with Lightning connector to your computer's USB port for syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet.
$14.95  $19.99Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (6)In StockAdd Apple 3ft Lightning to USB Cable for iPad Air 2 to Cart
Griffin Technology 3 ft USB to Lightning Cable for iPad Air 247%Griffin Technology 3 ft USB to Lightning Cable for iPad Air 2
The Griffin 3 feet USB to Apple Lightning cable is perfect for charging and/or syncing your iPad Air 2.
$10.00  $18.99Score 3.5/5Score 3.5/5Score 3.5/5Score 3.5/5Score 3.5/5 (2)In StockAdd Griffin Technology 3 ft USB to Lightning Cable for iPad Air 2 to Cart
TYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad Air 2TYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad Air 2
The TYLT SYNCABLE Charge & Sync Lightning Connector charges your mobile device via any USB power source, such as a USB car charger, wall charger, PC or laptop with no messy cables to get kinked.
$22.95  $29.99Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (3)In StockView TYLT 1ft SYNCABLE Charge & Sync Lightning Connector for iPad Air 2 Options
AZURA 6ft USB to Lightning Charge & Sync Cable for iPad Air 2AZURA 6ft USB to Lightning Charge & Sync Cable for iPad Air 2
Charge and sync your iPad Air 2 at the speed of light with the AZURA USB Sync & Charge Cable, a multipurpose cable that can do your multitasking for you!
$18.87  $29.99Score 4.9/5Score 4.9/5Score 4.9/5Score 4.9/5Score 4.9/5 (7)In StockAdd AZURA 6ft USB to Lightning Charge & Sync Cable for iPad Air 2 to Cart
Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air 248%Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air 2
Ventev's flat, tangle-resistant Charging Data Cable charges your iPad Air 2 and transfers your favorite photos, music, videos and more with ease.
$12.95  $25.00'Not yet rated.'In StockView Ventev 3.3ft Lightning to USB Charging Data Cable for iPad Air 2 Options
SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad Air 2SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad Air 2
The smartSTRIKE is a 2-in-1 charge and sync cable that will charge both devices at any time; without the fuss!
$19.95  $24.99'Not yet rated.'In StockAdd SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for iPad Air 2 to Cart
Incipio Lightning Charge/Sync Cable 3.3ft for iPad Air 2Incipio Lightning Charge/Sync Cable 3.3ft for iPad Air 2
Why not compliment your lightning-compatible Apple device with one of these high quality, vibrant colored charge and sync cables from Incipio!
$9.95  $19.99'Not yet rated.'In StockAdd Incipio Lightning Charge/Sync Cable 3.3ft for iPad Air 2 to Cart
Belkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad Air 2Belkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad Air 2
This two-meter (6.6-foot) cable features a reversible Lightning connector on one end and a USB plug on the other for convenient charging or syncing with your iTunes library.
$24.95  $29.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Belkin 6.5ft MIXIT Lightning to USB ChargeSync Cable for iPad Air 2 to Cart
KERO 3" Apple Lighting Nomad Cable for iPad Air 2KERO 3" Apple Lighting Nomad Cable for iPad Air 2
Carry the KERO Lightning Nomad Cable with you wherever you go and ensure that your lightning-compatible device stays charged!
$13.50  $29.99'Not yet rated.'In StockView KERO 3" Apple Lighting Nomad Cable for iPad Air 2 Options
Ventev 6ft Lightning to USB Charging Data Cable for iPad Air 2Ventev 6ft Lightning to USB Charging Data Cable for iPad Air 2
Now you can charge your Lightning device without worrying about knots and tangles! Ventev's Charging Data Cable provides 6 feet of convenient charging and syncing whenever you need it.
$18.95  $29.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (2)In StockView Ventev 6ft Lightning to USB Charging Data Cable for iPad Air 2 Options
mophie 4-inch Memory-Flex USB Lightning Cable for iPad Air 2mophie 4-inch Memory-Flex USB Lightning Cable for iPad Air 2
This super-flexible, high-current 4-inch cable charges and syncs any of your Apple devices with a Lightning connector and barely takes any space in your bag or at your desk!
$19.95  $24.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockView mophie 4-inch Memory-Flex USB Lightning Cable for iPad Air 2 Options
Belkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad Air 2Belkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad Air 2
The 90-degree angle protects the plug and alleviates strain on the cable. The Lightning connector makes it simple to sync and charge a variety of portable Apple devices.
$18.95  $24.99'Not yet rated.'In StockView Belkin 4ft MIXIT UP 90° Lightning Charge/Sync USB Cable for iPad Air 2 Options
KODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad Air 2KODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad Air 2
Original Kodiak Lightning MFI Charging-Data Cable Aluminum Housing Silver 6.6ft / 2m
$18.95  $24.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (4)In StockView KODIAK 6.6ft Apple Lightning MFI Charging-Data Cable with Aluminum Housing for iPad Air 2 Options
Ventev 6 in. Lightning Cable for iPad Air 248%Ventev 6 in. Lightning Cable for iPad Air 2
Flat & tangle-resistant, Ventev 6 in. chargesync cables are engineered to support higher output chargers, delivering up to 2.4A for Apple Lightning devices. Great length for portable battery chargers.
$11.95  $22.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Ventev 6 in. Lightning Cable for iPad Air 2 to Cart
Seidio Lightning USB Cable (0.2m) for iPad Air 2Seidio Lightning USB Cable (0.2m) for iPad Air 2
The Lightning Cable (0.2m) with high connectivity is a great way to keep your your iPad Air 2 charged and updated for use.
$9.95  $14.95'Not yet rated.'In StockAdd Seidio Lightning USB Cable (0.2m) for iPad Air 2 to Cart
Seidio Lightning USB Cable (1.0m) for iPad Air 2Seidio Lightning USB Cable (1.0m) for iPad Air 2
The Lightning Cable (1.0m) with high connectivity is a great way to keep your your iPad Air 2 charged and updated for use.
$11.95  $14.95Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (3)In StockAdd Seidio Lightning USB Cable (1.0m) for iPad Air 2 to Cart
Seidio Lightning USB Cable (2.0m) for iPad Air 2Seidio Lightning USB Cable (2.0m) for iPad Air 2
The Lightning Cable (2.0m) with high connectivity is a great way to keep your iPad Air 2 or iPad charged and updated for use.
$16.95  $19.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Seidio Lightning USB Cable (2.0m) for iPad Air 2 to Cart
[Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air 2[Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air 2
Meet TITAN LOOP - The Toughest Key Chain Cable on Earth. TITAN LOOP extends to nearly 25cm / 9in long, but loops in half to attach to your key chain, belt loop, backpack, or MacBook bag.
$24.95  $24.95'Not yet rated.'In StockAdd [Fuse] Chicken TITAN LOOP Key Chain Lightning Charging Cable for iPad Air 2 to Cart
Mobi Products 3-in-1 USB Charging Cable for iPad Air 2Mobi Products 3-in-1 USB Charging Cable for iPad Air 2
The Mobi Products 3-in-1 USB Charging Cable includes a Lightning, Micro-USB, and USB Type-C connections. Now you have the ability to charge different devices simultaneously.
$12.00  $15.00'Not yet rated.'In StockAdd Mobi Products 3-in-1 USB Charging Cable for iPad Air 2 to Cart
My iPad Air 2
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
