Shop accessories for other smartphones, one-cart checkout:   Palm Pre   BlackBerry   Android Devices   iPhone   Windows Phone
Device Selector  (Select Your Device To Find Compatible Accessories)Close
All Apple iPhone Car Kit Parts
Compatible With
View
Sort by
1. iGrip Universal Phone Holder for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4iGrip Universal Phone Holder for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4
Need a replacement Phone Holder for your iGrip Mount? This sturdy phone holster is exactly what you need to ensure your device stays safe and secure while mounted.
$12.95   $15.00Score 3.4/5Score 3.4/5Score 3.4/5Score 3.4/5Score 3.4/5 (30)In StockAdd iGrip Universal Phone Holder for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4 to Cart
2. iGrip Cigarette Lighter MountiGrip Cigarette Lighter Mount
Need a replacement Cigarette Lighter Mount? This sturdy mounting solution will ensure that your device stays safe and secure in the position you desire.
$9.95   $15.00Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (6)In StockAdd iGrip Cigarette Lighter Mount to Cart
3. iGrip Sturdy Swivel MountiGrip Sturdy Swivel Mount
The iGrip Sturdy Swivel Mount can easily be adjusted up and down and sideways for optimal viewing angles.
$16.95   $20.00Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (7)In StockAdd iGrip Sturdy Swivel Mount to Cart
4. iGrip Flexible MountiGrip Flexible Mount
The iGrip Flexible Mount is a suction mount with a strong, freely adjustable arm that adjusts the device holder to any viewing angle, and provides a safe and secure mounting for your device.
$9.95   $15.00Score 2.9/5Score 2.9/5Score 2.9/5Score 2.9/5Score 2.9/5 (14)In StockAdd iGrip Flexible Mount to Cart
5. iGrip Vent MountiGrip Vent Mount
The iGrip Vent Mount is a sturdy mount that features adjustable vent clips on the back that allow mounting on vertical or horizontal vent fins.
$9.95   $15.00Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5Score 2.8/5 (16)In StockAdd iGrip Vent Mount to Cart
6. Krusell Windshield Mount for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4Krusell Windshield Mount for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4
Perfect compliment for attaching your Krusell case to a windshield. Attaches to your windshield or other similar surface via a suction cup.
$14.95 Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5Score 2.5/5 (8)In StockAdd Krusell Windshield Mount for iPhone 4S, iPhone 3GS, iPhone 3G, iPhone, AT&T iPhone 4, Verizon iPhone 4 to Cart
7. iGrip Custom Fit Holder (Without Mount) for iPhone 3GS, iPhone 3G, iPhoneiGrip Custom Fit Holder (Without Mount) for iPhone 3GS, iPhone 3G, iPhone
Custom designed, this holder works with your iPhone 3GS, iPhone 3G, or iPhone. Slide & go! Your Smartphone conveniently slides into place and is held securely at all times.
$9.95   $15.00Score 4.7/5Score 4.7/5Score 4.7/5Score 4.7/5Score 4.7/5 (3)In StockAdd iGrip Custom Fit Holder (Without Mount) for iPhone 3GS, iPhone 3G, iPhone to Cart
8. THB BURY Mount Adjustable Knuckle for iPhone 3GS, iPhone 3GTHB BURY Mount Adjustable Knuckle for iPhone 3GS, iPhone 3G
Mount Adjustable Knuckle with 4 fixing points is used to attach phone cradles to an amps plate. To be used with Bury installed car kits only.
$27.95   $38.99'Not yet rated.'In StockAdd THB BURY Mount Adjustable Knuckle for iPhone 3GS, iPhone 3G to Cart
9. iGrip Custom Fit Holder (Without Mount) for iPhone 4S, AT&T iPhone 4, Verizon iPhone 4iGrip Custom Fit Holder (Without Mount) for iPhone 4S, AT&T iPhone 4, Verizon iPhone 4
iGrip Custom Fit Holder (Without Mount) is exclusively designed to fit the iPhone 4S, AT&T iPhone 4, or Verizon iPhone 4.
$12.95   $15.00Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5Score 4.3/5 (3)In StockAdd iGrip Custom Fit Holder (Without Mount) for iPhone 4S, AT&T iPhone 4, Verizon iPhone 4 to Cart
10. iGrip Dual-Support Suction MountiGrip Dual-Support Suction Mount
The iGrip Dual-Support Suction Mount is a versatile, elegant suction mount that is compact and foldable.
$16.95   $20.00Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5 (8)In StockAdd iGrip Dual-Support Suction Mount to Cart
Compatible With
View
Sort by
Shop by Category
Shop by Device
Customer Care
Powered by...
Our Customers Say...
